yamadog
He can't run or hide ha ha guess now I got to buy another pro s
They were on backorder for quite awhile but are slowly starting to be produced again.Hey guys anyone know where I can purchase the Gates belt? It seems like I can't find it in stock anywhere on the web?
I'd like to buy oneI have some. $130 shipped lower 48
You have mailI'd like to buy one
Pickup at your shop?You have mail
Sure.Pickup at your shop?
Hey Brock, trying to absorb all this. What are 10 series weights and are they adjustable??If I were you.
I would choose 10 series weights and a 66/44.46 or 50/44 full progressive.
Unless you have a welder and grinder10 series are Polaris weights, and no. Not adjustable
Not like I haven't seen it done before.Unless you have a welder and grinder
How are the Team rooster adjustables?Unless you have a welder and grinder
Inside' should wedge itself between both sheeves. Just checked it out with belt off.Brock, when I go to lay the alignment tool in the primary and get it ready to measure the gap between the tool and the front of the secondary, do I want to hold it up against the primary inside (crank side) or primary outside (panel side) sheave? I noticed there's some play in between the sheaves, which I assume is caused by the shimming of the spider and the type of belt a person is running.
